07-07-2022 11:08 AM
I had my account on hold since April as I wasn't able to find my device.Now I found my device but my account is Suspended and I am not able to pay. Please help.
07-07-2022 11:37 AM
Excellent. If you're still here then can you clarify that you were NOT able to pay while lost/stolen and that when you resume'd you were able to pay? If so then that's good to know.
07-07-2022 11:32 AM
Thanks for your help!!
07-07-2022 11:17 AM
Did your account get suspended due to no pay or you manually suspended it?
As long as you can log in to your account you should be able to add Other amount. Then manually restart service.
07-07-2022 11:16 AM
Are you able to login? What recording do you get when you dial 611? Do you remember if you left a balance on the account?
I would be quite sure that payments can be made while suspended whether self or non-payment. But maybe softech knows better.
07-07-2022 11:12 AM
@Shaw What was the error message?
You didn't put your account on Lost/Stolen, right? If you did , you have to reverse it first before you can pay. You go to go back to Lost/Stolen page and Resume service.
For payment, give it once more try using "Other (Enter the desired payment amount)" and then manually enter the plan amount . This usually work better than "Amount Due"
If that work and you are able to pay, then click the button Reactivate current plan if the button is around.
Then logoff My Account and reboot your phone
