01-04-2023 05:22 PM
I am going to England and want to use a sim card/phone plan in UK
Service
01-04-2023 08:28 PM
Lol....what's with the spoiler doing weird stuff?
01-04-2023 08:27 PM
Do you have a Samsung phone? Sometimes a brand new Samsung phone will lock to the first provider Sim card inserted in the phone. It's extremely unlikely that this will happen again however if for some reason it does you can contact Samsung Canada online or by telephone to get the unlocking codes for your phone.
Here are your options for your public mobile account while you travel.....
Here's some info on your Sim card/ plan options in the UK.....
https://londoncheapo.com/technology/uk-sim-card-options-london/
There are also extremely cheap plans available thru retailers such as Tesco etc....
You can also contact @Luddite via private message as I believe he can send you a free giffgaff Sim card before you leave so that you can be all set up once you arrive at your destination airport.
01-04-2023 05:39 PM - edited 01-04-2023 05:40 PM
It's unlocked, @bucknfoss
If you want to triple check, borrow someone's SIM card from another provider and try it in your phone to see if you can call and text. I'm certain you will be able to.
01-04-2023 05:37 PM
Exactly...that is my intention just need to make sure my phone card is unlocked
01-04-2023 05:35 PM
I had to unlock my phone from Virgin to join Public.
Just want to make sure Public didn't lock my sim card with them
01-04-2023 05:34 PM
so when you join public the phone is unlocked?
I know I had to unlock the phone to change providers but your saying public doesn't lock their sim cards?
01-04-2023 05:31 PM - edited 01-04-2023 05:31 PM
@bucknfoss with that. your phone is proved to be unlocked, you already tried different sim cards during the years, Virgin sim and PM sim
01-04-2023 05:29 PM
The fact that you went from Virgin to Public without unlocking already implies the phone is unlocked.
01-04-2023 05:28 PM
Do your homework here in Canada. Have the correct unlocked phone. Buy a SIM card at UK airport ..... you will find lots in vending machines.
01-04-2023 05:27 PM
I bought my phone from a kiosk that sells many different phones then joined Virgin
I then dropped Virgin and joined Mobile
Before I travel I would like to make sure my phone is unlocked
01-04-2023 05:24 PM
@bucknfoss did you get your phone from PM CPO site? All phone there are unlocked
if you got the phone from another provider, if the provider where you got it from can help to unlock
However, check if your phone is unlocked first, get another sim card from another provider other than Telus/Koodo/PM and see if it works. if it works on another provider sim, then you are good, the phone is unlocked
