unable to transfer from koodo
bayard0
So I tried transferring my wife's account over from koodo, but got an error 821 and that I need to contact a mod.
I also checked and my cc got charged
If a mod could reach out to me that would be wonderful
8 REPLIES 8
@bayard0 I took a guess it was prepaid.
That link I provided still would have helped you get connected to customer support for postpaid too😀 and get your port completed.
@pmbc
You may have missed the OP's response to @esjliv's earlier, similar guess.
Indeed, these are usually either the Prepaid Koodo port or the IMEI use on activation vs the Account#.
Guessing the OP's issues is use of the latter.
pmbc
@bayard0  if you have a Koodo prepaid you need to contact support to help you with the port.
Refer to this KB near the end re: Koodo prepaid port, How to choose your Phone Number (publicmobile.ca)
Here is the link for start the process with the agent for the port.  https://urlshortner.tiia.ai/Rqg6DB
@bayard0
using account number is safer and less failure than IMEI
did PM took the money yet?  If it did, you need to open ticket with PM support , provide them the account number and  have them to sort it out
To open ticket with PM support, message them:
bayard0
I used IMEI, maybe I should have used account #
bayard0
But I didn't say I was prepaid
dust2dust
Is that Koodo prepaid or postpaid? Did you use the IMEI or the account number? Check your credit card for any charges.
@bayard0
Here's the link to contact support for porting from Koodo prepaid.
