01-30-2023 05:02 PM
I am having an issue trying to sign in to my account. I enter my email and pw and it goes to a white screen with
{"message":"Unauthorized"}
Tried on my ipad and a laptop, getting the message on both. Any ideas?
01-30-2023 05:28 PM
If you're using a device with stored/remembered credentials, sometimes when these autofill, the device also attempts to automatically log you in.
If your device does this, do not tap the sign in button while it is trying to log you in as it will deliver an error message every time and appear to not let you login.
01-30-2023 05:14 PM
Hey there. Try resetting your password. It worked for me when I suddenly had login issues a few months ago; my old password didn't have the required special,characters. I had no idea what was wrong. Reset password and I have been fine since.
01-30-2023 05:08 PM
@softech wrote:@Kaia2014 try once more using Incgonito mode
but likely you have to open ticket with PM support:
Absolutely NOT.
Just to REFRESH or use different browser. Been there, done that... No need to bother agent with browser issues. Internet is FAR from perfect and particularly 'smart' (stupid) phones.
01-30-2023 05:07 PM
Hi @Kaia2014 we seen that error before . I think you need CS agent help once you got that error
please open ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
01-30-2023 05:06 PM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
01-30-2023 05:04 PM
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
01-30-2023 05:03 PM - edited 01-30-2023 05:04 PM
Try again incognito mode private mode there are cache issues and if the device has auto save email and pass let device sign you in and don’t hit log in also you can try another device or laptop
if you need further help regaining access open ticket
while your already here and logged in the community
01-30-2023 05:03 PM
Hi @Kaia2014
close all browser and clear cache/ cookies/ open inPrivate mode,from computer. Login again,
