11-06-2019 09:33 AM - edited 01-05-2022 07:52 AM
hi
i made transfer of my old number which was cancelled by previous provider to public mobile.
but I AM NOT able to recieve any calls , its saying not availble.
Although the data is working and I can make calls .
How this can be solved ?
Joining Public
11-07-2019 10:17 PM
@sharifa wrote:hi
A message saying something similar to "the caller you are trying to reach is unavailable" is often an indication of someone not answering the phone or of the phone being off when someone calls. Such a message would be heard if there is no vociemail on the account. This would lead me to beleive that your calls are still going to your old carrier, but that you don't have vociemail there.
11-06-2019 09:50 AM
i did
11-06-2019 09:49 AM
its more than 10 hrs now.I am able to use data and make calls ( from the number I am using) but not to receive any
11-06-2019 09:42 AM
You would need to submit a ticket to a moderator by clicking on the question mark on the bottom right.
11-06-2019 09:36 AM
When did you tranfer/port your number? It can take several hours for port to be completed.
If more than half a day, then you may need to contact moderator to help complete the port. Click on the question mark on the right lower corner of website. Type contact moderator and follow instructions to start ticketing process to get moderator help.
You should still be able to use your old carrier SIM card until port is completed.
![](/skins/images/02B49C0B2FC614613D221373CF8AAEF5/responsive_peak/images/icon_anonymous_message.png)
