01-28-2022
12:22 PM
01-29-2022
10:22 AM
Dunkman
11-06-2022 02:43 PM
Can you not block the number on the hand set? My Panasonic hand set allows me to block 50 numbers and newer models can block 500 numbers.
01-28-2022 01:00 PM
@tonymeehan Was it just a single number targeting you?
You probably know there is no way to block random sales call or Caller ID spoofing. If it is one particular person trying to do this, call blocking would work but not with your current setup. You might need a newer cordless phone instead.
Of course, you can also try to change a new number and get away from that particular caller. You can make phone number change as many as 4 times every 30 days.
01-28-2022 12:57 PM
You may consider adding yourself to the national Do Not Call registry here: https://lnnte-dncl.gc.ca/en/Consumer/Register-your-number/#!/
This may or may not help at all, but certainly can't hurt.
01-28-2022 12:38 PM
01-28-2022 12:36 PM
CS6519-4
01-28-2022 12:34 PM
What exact model?
Vtech has "Smart Call blocker" on some model. check if you have Call Block button on the handset or the base or from the menu
01-28-2022 12:33 PM
Do you have the model number of the Vtech phone? Might be written right by the charging station
01-28-2022 12:31 PM
Vtech
01-28-2022 12:31 PM - edited 01-28-2022 12:31 PM
Yep, there is no easy way to block numbers on the WF721 unfortunately.
01-28-2022 12:29 PM - edited 01-28-2022 12:31 PM
@tonymeehan Oh you are using WF721. No, I don't think it gives you the option. And PM does not provide any service that helps blocking particular number
What kind of handset you connect to the WF721? Panasonics? some Panasonic cordless give you such option. Other phones could have such option, too. Give us the brand/model and will try to find the way
01-28-2022 12:26 PM
WF721
01-28-2022 12:25 PM
01-28-2022 12:24 PM
There is no phone app - it used to be a landline phone
01-28-2022 12:23 PM - edited 01-28-2022 12:24 PM
Do you know what the model of that ZTE device is? Usually written somewhere on the back or the side.
PM does not have any blocking service. So, you will have to try it on the device level
try this
