04-08-2022
12:31 PM
04-08-2022
05:07 PM
computergeek541
I need to have the text request resent to Bell to transfer the number
04-08-2022 04:44 PM
Holy @frig I think you should be able to be fixed up with @Yummy phone number they are sending you.
If still issues for your port methods to contact CSA *Customer Support Agents* are found here:
https://publicmobile.ca/en/ns/get-help/articles/contact-an-agent
Remember, when you insert your Public Mobile SIM card to restart the phone with the SIM inside.
I would also recommend performing a Reset of the device's Network Settings when changing providers.
04-08-2022 12:49 PM
are you porting to PM from Bell or vice versa?
04-08-2022 12:42 PM
If you missed the PAT (porting authorization text) SMS from previous carrier, then can call the Telus/PM porting number which I'll send you via private message (check your community inbox) and they will be able to request another authorization SMS to be sent so it's important to keep the old SIM in his phone in order to respond with a Yes to that SMS.
