04-07-2022 10:47 AM
hi, i have a problem with my account when i click on password, it tells me to put my emzil with which i created my account, i put it after i click on continue. after clicking on continue there is a small red message at the top that appears telling me to try again later every time for a long time. I don't know how to solve this problem because there is no one to do it, it's out of here.
04-08-2022 02:00 PM
hi @Michel242 is your phone working with your sim at all?
You just cannot login but with working service? or your service does not even work?
maybe open ticket with PM, Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
04-08-2022 01:45 PM
Can you call and text? If not, what do you get when you dial 611?
04-08-2022 01:43 PM
the last time I put connect was when I had created my account and received my sims card 4 years ago after that I never connected
04-08-2022 01:40 PM
It’s tell me the number phone entered is invalid or your may have created your profile already. If you’re forgetting your password click on the link. And after they tell me to put my email and the same problem was here
04-07-2022 11:07 PM
@Michel242 - The password field should not ask you for your email. I wonder which area you are trying this in?
Have you created a MyAccount/Self Serve yet? If you activated in-store you may not have set one up yet.
You can register for one here, if this is your case: https://selfserve.publicmobile.ca/self-registration/
04-07-2022 12:41 PM
Try clearing your cache, cookies and go incognito on your browser in an hour.
Too many attempts to login so you are locked out.
04-07-2022 10:55 AM - edited 04-07-2022 10:56 AM
When was the last time you accessed your self-serving account?
The account might be only temporarily locked for an hour due to too many (5) attempts. You might want to wait an hour and try again.
If you are positive, you entered id/pass correctly before being locked out, try different browser.
If you still have issue logging in, try the Forgot password link to reset the password. You will need to answer security questions, though.
If you don't know the answer to the security questions, you can open a ticket with CSA to have it reset.
04-07-2022 10:53 AM
@Michel242 Has you're account worked and received a payment within last 89 days? If I had not been active for awhile at the 90 day mark it is closed and number gone.
If its recently been activethr. Contact support.
Contact customer service agents.
Open a ticket via
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗
or send a private message to
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/2243
