text messages issue
daddy77
after transferring my number from my old service, I can't send or receive text msgs
fixin1
@daddy77 - Please use this link to contact CS_Agent:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
@daddy77
try using direct message (if you still get an error, let us know the exact error message)
daddy77
i try to create ticket , it gives me error and can't submit ticket
@daddy77  It’s a known  issue for new activations and sms not working . Ask support to fix for you
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
fixin1
@daddy77 - There is a current known issue with texts: https://productioncommunity.publicmobile.ca/t5/Get-Support/Under-Investigation-Ongoing-Issue-Text-Me...
Please contact CS_Agent for a fix of the SMS / MMS issue:
Submit a ticket via Chatbot:
This is an issue affecitng new customers.  You'll need to contact a customer support agent to fix this.  Please open a ticket using the chatbot at https://widget.telus.tiia.ai/publicmobile/publicmobile.html or by using the support option in the Public Mobile app.
