05-22-2024
08:55 PM
05-22-2024
08:57 PM
computergeek541
I am a new customer, I paid, and chose esim, but my phone is not compatible. the screen is stuck and it says to contact an agent. I did purchase a physical sim just in case, how do i get unstuck?
05-22-2024 09:06 PM
@MJCanario wrote:i went through all of this and it says someone will reply in these community pages?
Account issues need to be discussed privately. Public Mobile customer support agents will not discuss these issues in detail in the message forums and anyone with an internet connection can view this information.
05-22-2024 09:03 PM
thanks again!
05-22-2024 09:02 PM
@MJCanario wrote:s20 FE thanks, I have not heard anything back?
@MJCanario - Your phone won't be compatible on Public Mobile's 5G (As it isn't really a huge issue) but it is due to a Samsung and TELUS agreement to not have 5G display on Public Mobile and Koodo on the S20 lineup and when Public Mobile and Koodo introduced 5G plans it was too late - the S20 didn't offer any major carrier update.
LTE is as fast as 5G so you won't have any issues with data just because your phone shows LTE instead of 5G.
05-22-2024 09:00 PM
05-22-2024 08:59 PM
thanks
05-22-2024 08:59 PM
@MJCanario - You can contact CS_Agent here:
Submit a ticket via Chatbot:
⚠️ Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article! ⚠️
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
05-22-2024 08:58 PM
05-22-2024 08:58 PM
@MJCanario wrote:I am a new customer, I paid, and chose esim, but my phone is not compatible. the screen is stuck and it says to contact an agent. I did purchase a physical sim just in case, how do i get unstuck?
Customer support agents are contacted by using the chatbot to open a ticket. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Arrangements will be made to change to this to a phsysical SIM card activation.
05-22-2024 08:57 PM
what phone do you have?
yes, support can help, they can advise to try esim again or change to physical. Please message them here
