status of account
bajigar
Hi,
Could someone help to check status of my account.
I tried resetting password but not getting email code.
I had paused account 2 months ago.
@bajigar   are you trying to restart the account?
as @HALIMACS said, try *611 to check the status
or from a landline, try 1-855-4PUBLIC and then enter your phone number and it will tell you the status
HALIMACS
@bajigar
dial 611 from your device and you will hear messaging about the account status.
@bajigar  Please remove your email address
we cannot help as we are just customers, but PM support can.  Please open ticket with PM support as below:
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Yummy
Remove your personal data from public forum.
You should not reset password if you you KNOW it is correct one. But since you did, wait 20+ min and try again.
To log in again: Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
When you get in, you will see your account status.
@bajigar  This is public forum you see under your name to the right arrow by time stamp tap it and edit your personal info
