Roaming overages
mithramd
HI. If I buy a US roaming package with data does it just stop working at the end of the gb amount or do I get charged overages?
Metal1967
@mithramd  Rotten part is.. depending geographically where you go it may not work at all.. it’s a crap shoot
HI @mithramd   no overage charge at all.
In fact, on overage for anything here.  PM is prepaid, you buy before you use and no overage charge
will13am
@mithramd , this brand is 100% prepaid format including add-ons.  So if you run out of data usage on the roaming add-on, the data will simply stop.
@mithramd   no overage charge, it will just stop working
if you need more, and the 15 days has not expired, yet, you have to buy a different add-on and not the same one
If you need to buy the exact same one before the 15 days expiration, you will need to open ticket with PM support for them to help re-buy same
