sms from outside Canada
AprilGr
The sms from my Spanish bank are being bloking by Public phone. So, I can operate with my bank, What can I do?
14 REPLIES 14
@AprilGr wrote:
My husband and I share the account bank. We activated mobile phone the same day, months ago. He doesnt have any kind of problem. Its just me. I have already talked with the thecnical service of my bank and, according wiht them is public phone who is bloking the sms.
thanks
@AprilGr   I would like to do a bit more research on this for you, but I might need this info:
1. What mobile carrier your husband is using?
2. What sender number or short code number?
3. is he still receiving the text message today?
AprilGr
thanks a lot. Not working
AprilGr
thanks
AprilGr
thanks
AprilGr
I activated the line months ago. thanks.
AprilGr
thanks, not working.
AprilGr
I am able to receive any sms from whatever place in the worl. The problem is just wiht my bank.
Thanks a lot
@benfatto wrote:
Try ”forcing" change of your SMS settings:
  1. Go to Settings
  2. Then go to Mobile networks and select a network other than Public Mobile, Telus, or Koodo
  3. When you exit the menu the phone should lose the network.
  4. Repeat the process and select Public Mobile as your mobile network.
This procedure will force the update of the message centre number. You can verify it in your message settings.
If it's actually a short code being used by the bank.
Unfortunately, PM does not do a good job supporting short codes. https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/What-short-codes-are-supported-by-Publi...
For those not listed you will need to contact the organization for support: https://www.txt.ca/en/current-short-code-programs/
Ultimately though  you may need to discuss the problem with your bank and find a workaround.
SMSC has no effect on incoming text messages.
dabr
@AprilGr     Other customers in the past have also posted about not being able to receive shortcode text messages from overseas banks so it's likely PM doesn't support all international shortcodes.
However, another customer was able to receive the shortcode message from a French bank after being advised to set their network setting to 3G/WCDMA.    I have no idea if this will work for you but it's worth a try, otherwise you need to ask customer support if they support shortcodes from this particular bank in Spain.
Here's a link to the thread suggesting 3G option:   https://productioncommunity.publicmobile.ca/t5/Get-Support/2FA-SMS-from-Bank-in-France-not-arriving/...
@AprilGr   Did you ever get the SMS from your Spanish bank ?  You got it with another provider or you ever got it with PM?
Verification text is short code.  Overseas short code might not work, but usually is not an problem with your provider but a problem on the sender.  Providers does not really block your oversea text but your text actually never reach here.  It often problem with the sender as send did not setup their system to send text overseas
If you have got the Spanish text from another provider before, then did you just port your number into PM lately?  if that is the case, it could be because you have just activated within a week.  It's a routing issue and usually will clear up within a week
VIP_Tech
Hi @AprilGr
if activated new line, the SMS to receive the verification code. is will take time from 3 to 5 business days,
benfatto
  1. Go to Settings
Lieux
@AprilGr  Try to join Public Mobile to let them know your problem. Click on the chat bubble on this page and write your problem. After search for the CONTACT US button and for the SUBMIT A TICKET. And they will help you.
Yummy
Are you saying that SMS from Spanish bank are not delivered to your phone having PM service in place?
Are these short authentication SMS?
Can you receive any other SMS from Spain?
