simcard
wcheung73
my sim card could not use on my new phone
7 REPLIES 7
@wcheung73
Check to see if your new phone is unlocked and not Blacklisted. Dial *#06# to get the IMEI number of the phone.
https://www.imei.info/
 @mariajime : We don't yet have any updates from the original questioner. So what problems are you having? Any errors? I have an A32 made for the Canadian market that works perfectly here.
mariajime
Mine fits perfectly on the slot. I have tried other ways but I am sure I am putting the right way.
mariajime
Same thing happened to me. Samsung Galaxy A32 ( it's unlocked)
JL9
Is it a fitting issue? Or a sim error when you put it in?
hairbag1
What make / model is new phone ?
@wcheung73   is it the size of the SIM card?  If so, do you see any spacer/frame around that you can peel them off carefully? Like this:
or other error?
