05-16-2022 04:16 PM
05-16-2022 09:34 PM
Check your Cellular Data to see if it is turned on.
Also login to your account to check your data usage.
05-16-2022 05:00 PM
@ericamark - if above suggestions have been checked tried, and still issues, try restarting your phone, removing and reinserting your SIM card, or toggling into then out of airplane mode.
05-16-2022 04:58 PM
What plan do you have? the 15 plan (and even the 25 plan quite frankly) can deplete your data quite quickly if you are not careful. Your self serve account will determine if you have any data remaining.
05-16-2022 04:22 PM
HI @ericamark if you are on iOS, make sure your carrier profile is up to date (and your OS as well)
For Android, check the APN settings
or a quick way is to try Reset Network settings
05-16-2022 04:20 PM
@ericamark wrote:My data isn't working??
Was it working before? Or, are you a new customer or have a new device? I would check your phone's setting. Here is a good place to start: https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
Another possibility (if data was working earlier) would be that you may have run out of data on your account. Log into your account and see how much data is indicated as remaining. If it doesn't show any data amounts on the first page for Data and Add-ons, it has all be used.
