Data roaming toggle gone
CarolynGoGlass
Hi my toggle to turn data roaming on and off is completely gone.  I’ve googled and it appears to be something the carrier controls. I recently returned from Spain and used an eSIM, but the eSIM has now been uninstalled. I still can’t find this toggle and I need to cross over into the states so I need to be able to roam
DennyCrane
what type of phone?
@CarolynGoGlass
get Customer Support to look into the issue. Click on the orange chat bubble on lower right side of the page to start the process.
If that fails, use this link to dm Customer Support...
The Community inbox will be highlighted when they respond...
CarolynGoGlass
Thank you, I did try that, no luck.
hairbag1
@CarolynGoGlass
try doing a network re-set to see if that helps.
