sim card
cathbob
got talked into another company plan yesterday, cancelled right away now need to redo everything with Public Mobile. How do I get a sim card? Can I purchase at a store or does it have to be online?
hi @cathbob
just to add, if you already moved away from PM, you will need to setup as a new account
cathbob
thanks everyone. heading to Telus in the morning
hi @cathbob
Buy a PM physical sim card from Telus or Koodo or Mobile Klinik stores or via Amazon:
 Telus or Koodo or Mobile Klinik store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Phil_Adelphus
@cathbob   You can purchase a sim card at a corporate Telus/Koodo store, call ahead to check their stock.
Chalupa_Batman
Hey @cathbob
If you need a physical SIM, Amazon sells them. Click on AMAZON for the link.
Or locations near you that have a SIM. TELUS STORES
