ESIN CARD
Way1
CAN I GET A FREE ESIM CARD FROM PM AS I  UPGRADE MY  PALN TO $35/M? THANKS
Phil_Adelphus
@Way1   You don't actually need to change sims when you change plan, just in case you weren't aware.
sorry @Way1
no free esim for existing customers converting physical sim to esim.  But it is only $5 to change to eSIM.  But once you changed to esim, you can get free replacement.  So, it is more a one time fees
kb_mv
@Way1 Changing sim types and changing plans are not related or dependant on one another. You want to switch to esim from your physical sim? I believe you are on the hook for that.
