18 hours ago
Hi there, I was wondering if it's possible to register the same e-sim on two devices: my usual iPhone, a secondary device, and an iPad. I also want to use the data on an iPad when I don't have available Wi-Fi.
Are there any options for this? If not, what are the available alternatives?
Thanks!
8 hours ago
Thank you everyone for your answers and suggestions. much appreciated! I think using hotspot will be my go to then. Thank!
14 hours ago - last edited 14 hours ago
@Fxttor You can connect the iPad to the iPhone's hotspot and use it as wifi as @Handy1 suggested. If you want calls and texts to work on your iPad you can set it up to allow calls to work on both, instructions for that are here
https://support.apple.com/en-ca/guide/ipad/ipadf97892b2/ipados
15 hours ago
hi @Fxttor
always one sim for one phone number. So, what you want to do cannot be done. If that iPad needs mobile data, another eSIM with another account is the only way
15 hours ago
@Fxttor You only option is to create second account with new SIM card and email to use in the iPad . But because the iPad doesn’t have voice feature you mainly using it for data might be better to just hotspot your phones data to the iPad when you need data on the iPad on the go . Otherwise second account it is and you.can use the refferal code from your first account to create the second account and reward both accounts win/win
17 hours ago
Unfortunately, you won’t be to have 2 eSIM on 2 devices. As you can only have 1 SIM/eSIM per account/device.
