rewards vs public points
publicsteve1
I'm on an old 3g plan, and have some monthly reward reduction for referrals, years a customer and credit card payment. I'm thinking of moving to the 5g plan on sale now. Questions:
Will I loose my monthly reward credits?
Will I be forced to move to the "public points" system?
Say I get the $50 100 Gb plan - will that increase in cost over time or does it stay as is like my current 3g plan has?
Do I need a new sim card?
Thanks
@publicsteve1  No you will keep rewards the way the are now there tied to your account not your plan I can confirm I just switched plans and keep my rewards
HI @publicsteve1
1. you won't loss your current monthly reward credit, you will get the same
2. you won't be forced to move.  Changing plan won't change your rewards system, you will still on the legacy one if you are currently on
3. the plan price will stay once you are on it
4. no new sim card needed. The same one can be used for 5G plans
