02-02-2022 09:34 PM
I am new to Public Mobile. I do not know my voicemail password. When I go to the option to reset pswd, it does not work. It wants me to log off and tog lo back in to try again. Still does not work. Can anyone help. Jake
02-02-2022 11:19 PM - edited 02-02-2022 11:28 PM
Thanks, maybe I should change my PIN when I dial the 4001 number. They are both the same.
02-02-2022 11:17 PM
02-02-2022 11:15 PM
HI @speakout you got error when you try to reset password here: https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/reset-voicemail-password/ ?
did you try using another browser or even try on another computer or phone?
02-02-2022 11:07 PM
You need to enter your 4 PIN to access your voice-mail.
02-02-2022 10:01 PM
If you have set up voicemail but need to reset your 4 digit voicemail pin # then follow this protocol before logging in and getting your voicemail pin # reset.
02-02-2022 09:41 PM
@speakout wrote:I am new to Public Mobile. I do not know my voicemail password. When I go to the option to reset pswd, it does not work. It wants me to log off and tog lo back in to try again. Still does not work. Can anyone help. Jake
@speakout - did you set up your voicemail?
See Set up here: Set up Voicemail (publicmobile.ca)
Alternatively, check which Voicemail Access Numbers is near you (you can use any really), and set it up as a contact:
02-02-2022 09:41 PM
02-02-2022 09:38 PM
If you try to access your voicemail try your 10 digit number.
