12-29-2024
03:10 PM
12-29-2024
05:35 PM
computergeek541
how can I get a refund, I cant login in the app and the website is impossible to try and do anything with
12-29-2024 10:27 PM
I am having the same problem as you. This is the following response I received after some back and forth messaging going nowhere (removed some information I had requested for):
Here you can find a copy of our service terms and conditions:
We do not offer a refund for used services.
Thanks for your understanding!
Kind regards,
Angelo.
I responded back I did NOT use the service, I was unable to even access the service because of inability to even log into my account. I am not trying to escalate to supervisor for a refund because literally it's an unused service... unable to use it.
12-29-2024 07:09 PM
Thank you very much I will try this
12-29-2024 05:05 PM
12-29-2024 03:13 PM - edited 12-29-2024 03:14 PM
@graeme111 pm is pre paid and no refunds ? But if you can’t / haven’t activated support will give refund or help you gain access
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
