red x beside picture in text msg slow to send
skidooking
same as above i just switched from lg g3 to g5
now slow to send the other person cant rec say failed to download attchmet
sent a test thru telegram and works my data is on
am i missing something
thank gary
10 REPLIES 10
@skidooking
Are you sure your data is working? Or are you on WiFi? You have to have mobile data to send MMS. On LG phones that usually requires you back up your phone and do a factory reset.
@skidooking force close the text app and restart your phone. Stay safe.
@skidooking
Hmmm....will have to figure this one out.
BTW....if you want to address someone so we can figure out which member you're answering just tap the "@" key to tag someone and a box will pop up with usernames in it or type the name followed by a space and the username will pop up and tap on it.
@skidooking check this thread out. maybe you should contact moderators or copy the APN settings posted in the link
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Re-Picture-messages-unable-to-send...
skidooking
done 3 times same
skidooking
tryed same
skidooking
done still the same
@skidooking
Toggle airplane mode on/off. Maybe you have a weak connection to the network.
After the network reset. Restart your phone if it doesn't automatically do so,  enable data and try sending an mms message.  If it fails check your APN settings change it to the one below.
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: Not set      - or - default,mms,supl   ( if your mobile hotspot is spotty add "dun")
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Stay safe
popping
thank gary
1.  Sending/receiving picture MMS need data enabled.  You don't need a plan with data.  But you need to enable data.
2.  For LG phone, you need to do a network reset on your LG phone first after changing to a new provider before getting your mobile data working again.
