12-02-2024 11:55 AM - last edited on 12-02-2024 01:54 PM by computergeek541
Hi, I have recently (2 days go) ported into a Public Mobile plan from Freedom Mobile. I am unable to receive calls and unable to send/receive text messages. Data & outgoing calls seem to be working fine. This is critical, how can this be fixed asap? I chose to get an eSim
12-02-2024 12:03 PM
HI @RSidd
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
