Pin number
Mama_bear
Where do I find my pin number
Mama_bear
Thank you
slusagm
Account pin is not part of the activation step now.  but you can  set it up yourself here
https://myaccount.publicmobile.ca/en/account/reset/pin
hi @Mama_bear
you have to set it up here using this link
eddieO
@Mama_bear below link will help you reset your pin in case you have forgotten it:
