reactivated plan, no service
tyrannosaurus
title
how long until my service gets put back on, if ever?
10 REPLIES 10
CS_Agent
Customer Support Agent
Hi @tyrannosaurus
WeMVe replied to your message, please check your inbox 🙂
Thank you
Syed
@tyrannosaurus wrote:
that solution did not work.
i guess it is up to the moderators.
thank you anyways, but re-topping up your account after a de-activation and then re-activation should always work. i'm surprised there is no immediate switch to "service on" to this effect.
Yes it should. Robot Mad
tyrannosaurus
You can write a message to the moderator if anything helped...
@tyrannosaurus and you will need to wait few hours to 2 days for a reply...be patient they will help you..Smiley Happy
popping
once i topped up, the money was immediately spent and it went through.
i looked at my DATA and it said my plan was active.
i already did a reset.
Can you call or text out?
If not, try the lost/stolen phone trick to re-provision your plan features.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is up to 48 hours. Good luck.
tyrannosaurus
popping
title
What is your plan?
How much did you paid to reactivate your plan?
Is your account status active or suspended on your overview page?
How much is the amount of available fund on your overview page?
It usually takes a few hours for payments to go through. Check if the money has been taken from your account and if your account status had been changed to Active.
Try adding $1 more to your account and restarting your phone.
tyrannosaurus
it is what it is.
i re-activated my plan by topping up, and still have no service after a couple hours.
Lieux
@tyrannosaurus
We need more information to help you...what happened???
