re-activate sim?
03-21-2024 11:32 PM
Hi guys
I downloaded a new e sim for my 1 phone. Somehow I deactivated my physical sim card on that same phone. Is there any way to re-activate it?
Joining Public
03-22-2024 06:04 AM
@jesse39 Did you download the esim to the same account as the physical sim?
03-21-2024 11:58 PM
@jesse39 the esim not ring?
can you remove the physical sim and test calling the esim number?
03-21-2024 11:56 PM
it is active. i have an android phone. when I call my number it goes to voicemail and doesn't ring. settings>network>sim. it shows both active, however, settings>network and internet>calls and sms, it says unavailable.
03-21-2024 11:46 PM
Tap Network & internet and then Mobile network.
Select the SIM you want to turn on. and Tap Use SIM.
03-21-2024 11:39 PM
I have a pixel 7. when I go to settings, network and internet, under calls and sms, it has public mobile #### (unavailable) and the public mobile 2 (my second sim)
03-21-2024 11:35 PM
just go to sim manager and set it active
or on iPhone, set the label and enable "Turn on this line"..
