"Check Eligibility" button when transfering number not doing anything
DraftKnot
Hi there!
Trying to transfer a number from Speakout to Public. When I enter the number and hit the "Check Eligibility" button it doesn't do anything; I see a little spinning circle then it disappears. Is this service down right now? I have tried it on Firefox, Chrome, and Edge browsers.
Thank you!
11 REPLIES 11
darlicious
@DraftKnot
I am happy to hear everything worked out for you! Welcome to public mobile.
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
DraftKnot
Yes I followed darlicious's comment above. Basically, submit a ticket to support with all required information. It was resolved within an hour for me. Links and additional infor are in their post above.
Good luck!
@whelab wrote:
I have the exact same problem, my number is with Lucky Mobile. It just spins and does nothing. Did you have it resolved?
This is a website issue. Please try again at a later time.
whelab
@DraftKnot wrote:
Thank you for the reply. I am already activated with a brand new number.
@DraftKnot
Check to see if your number can be ported from this Koodo website (Telus owns Koodo and Public Mobile), so, same allowances here:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
If the number is eligible, and the self serve section is not working for you still, ask customer support (CSA) to help with the transfer of the phone number.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
@DraftKnot   Yes, I suggest to open ticket with PM Support
But if you want to try again, you can try :
1. clear cache, close all browsers and relaunc
2. Try using Incognito mode/InPrivate Mode
3. Try on another browser (Edge/Chrome/Firefox)
4. Try on another computer
DraftKnot
This is what I am doing
It just hangs here and doesn't do anything. Thanks again for the help! I will try submitting a ticket as mentioned above I guess.
Then try to request from My Account->Change  number and then select "Transfer a wireless or wireline number from another provider "
https://selfserve.publicmobile.ca/Overview/ChangeNumber/https://selfserve.publicmobile.ca/Overview/ChangeNumber/
darlicious
@DraftKnot
Please refer to this post by @popping for how to port from Speakout.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Porting-number-from-Speakout-Apply-also-t...
DraftKnot
@DraftKnot
Please activate with a brand new phone number first. After activation is completed, you can then request porting from within your Self-serve/My Account
There, you will not be asked what old carrier is.  Simply put  the IMEI  in the field: Equipment Serial Number.   (You can get the IMEI by just dialing *#06# on your phone)
Do not use an account number and do not fill in the PIN for porting when coming from Speakout
