02-23-2023 11:34 AM - last edited on 02-23-2023 12:30 PM by computergeek541
Your entire public mobile website is BROKEN in Firefox and has been BROKEN for 13 months, when will this be resolved? The website only works in chromium based web browsers. You cannot login on Firefox and if you open the developer console there are over 390 JavaScript code errors, this is insanely unprofessional to leave a website completely broken.
04-24-2023 05:04 PM
Did all that, the website is still broken in Firefox, you can see about 35 errors in the console. It's just bad coding the devs clearly only tested it in chromium because they are blatant errors.
03-04-2023 04:19 PM - edited 03-04-2023 05:35 PM
Broken for me too, on Firefox for PC. The login page displays a bunch of error messages.
Update: Actually I got it working. I have a Firefox addon called "Dark Reader" which alters the colour of websites to give them a dark background. I was able to log in to my Public Mobile account after disabling that.
02-23-2023 12:24 PM
It’s not broken when using chrome or safari.
02-23-2023 11:49 AM
I had to switch from Firefox (older version due to add-ons I love to use) to Chrome in order to use PM web site.
Try Chrome or Edge (on PC).
Try incognito mode to see will it work.
02-23-2023 11:46 AM
I primarily use Firefox. I even have some add-ons doing things which would presumably make it harder. It works fine. Maybe you need to allow at minimum session cookies or only just some of their javascript.
02-23-2023 11:41 AM
@justindb83 do you have dark theme extension on Firefox? it could be the reason
Try to launch Firefox with NO extentsion and see if it works
and post us the screenshot of the error
02-23-2023 11:35 AM
@justindb83 Try again incognito private mode or another device or lap top there are cache issues
