08-23-2022 11:31 AM
I put my sim card into my samsung s4 phone but it shows at top of screen simm card unregistered. It is a new simm card registered and paid for New public mobile account plan paid for. Any help would be appreciated,
08-23-2022 03:20 PM
turn off device and take out SIM card and insert back on.
if still not works then contact support team by > CS_Agent to check it.
08-23-2022 01:02 PM
If the sim card works in another phone @67Firebird , perhaps this phone is locked to its previous provider..contact them to unlock it for you.
Sometimes removing, and reinserting your sim card may help with this message if it is just not seated properly.
You may want to check also, just to make sure, that your phone is not listed as blacked here : Check the Status of Your Device in Canada | DeviceCheck.ca
08-23-2022 11:44 AM
If Yes then you must have entered your sim number and might have selected a phone number or ported a number from other provider. Login to your account and check once
08-23-2022 11:43 AM - edited 08-23-2022 11:45 AM
HI @67Firebird is the same sim card working well on another phone?
08-23-2022 11:42 AM
Did you do the registration process online by creating a profile?
08-23-2022 11:33 AM
If you do a full power cycle off and on do any messages pop up through the restart? If so then come back with the exact wording from them.
