yesterday
I have 2FA active for one of my accounts, but it still has my old number.
I have tried, multiple times, going through the "change number" steps they provide, but they do not work for me (For one reason or another).
They keep sending texts to my old number, letting me know my code, but I no longer have that number as I changed it on my SIM card.
Is there any way I can access my old number, or get my old number back, so I can receive these codes?
The Number change was done within the last week, if that helps in any way.
yesterday
@RaveBbit did you update your phone number in the EverSafe section "Manage Login (Secured by EverSafe)"?
If you already have then message a support agent, they should be able to assist you.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
