07-03-2023 02:35 PM
i can not finish my order. it shows postal code doesn't match billing address, what should i do?
07-03-2023 02:42 PM
Match the postal code to the billing address? Are you typing all caps (not sure if that's necessary)? Are you adding a space (not sure if it will allow you to anyway)? Check your credit card to make sure nothing has charged just in case.
What specific order screen are you on?
07-03-2023 02:41 PM
@joeLiu - double check what your card company has for the postal code.
07-03-2023 02:40 PM
@joeLiu are you subscribing or buying sim card?
