Can Current Plan Use New Promo of Similar Plan?
Mondocanuck
Is it possible to get promo plan of 20 GB at 4G Speed for $39 from my current 15 GB at 4G speed for $40?
@Mondocanuck  Yes and the best part is if your in old rewards you get to keep those too . I just switched to this plan my self and kept old rewards and add ons check it out
Mondocanuck
Excellent. I've change my subscription for next renewal. Thanks for your help! 😀
@Mondocanuck yes, the plan is open for everyone, new activation and existing subscribers.  Just go to My Account, and click Change Subscription from Overview tab (please note screenshot below is for choosing a different plan.  For you, make sure you pick the correct one, and make sure you choose Change on Renewal  to avoid losing money from the current cycle)
https://myaccount.publicmobile.ca/en/account/plan/change-planhttps://myaccount.publicmobile.ca/en/account/plan/change-plan
dust2dust
Log in to the account and change plans and see if it's available and select it and choose change at next renewal.
