02-09-2023
11:40 AM
02-09-2023
12:00 PM
computergeek541
02-09-2023 12:28 PM
Lol.....well that wasn't hard to find when comparing 2 posts to 24,000+.
02-09-2023 12:25 PM
I suggest that you use your phone and not worry about points. Points will very slowly accumulate with every payment you make and the number of years your account is active. Depending on the plan you have it make take more then one year to get enough for one month free but also maybe not.
02-09-2023 12:20 PM
HI @darlicious that's why no direct copy and paste from others. Understand it and write it out yourself
did Andy copy yours?
You reminded me of another user like to do that before
02-09-2023 12:17 PM
The problem with @AndyPM 's post is its copied from a response to a question about the difference between the two rewards programs and whether that OP should switch to the points program.
Suspending your plan has no affect on anniversary points you will get them regardless on your anniversary date. I can back up the original author on that one. 🤫🤔😉
02-09-2023 11:55 AM
Sorry @AndyPM there is NO more Loyalty rewards on Public Points. They only get Anniversary points, 10 points every year no matter how long you are with PM
Also, I am not sure this is correct: Suspending your plan does not affect the awarding of these points.
Likely it will affect depends on the length of the suspension
02-09-2023 11:52 AM - edited 02-09-2023 05:51 PM
02-09-2023 11:45 AM
You get 5% in Public Points for all spending you have with PM, your regular renewal and your add-on purchase
Like other point programs, you collect for enough points to redeem for "prizes". You can redeem 15 points for $15 bill credit. Or you can redeem for add-on, which is a bargain, it is generally 33% cheaper than paying for add-on
If you are new activation, you should get 3X points now. The regular points will be added to your My reward account immeidately after you "spent" your money with PM, the extra 2x points will be there 48 hours later
For your current points, check the reward site here (same login name and password as My Account)
02-09-2023 11:43 AM
Hello @bogag517 ,
Read over this link: conditions.
"Public Points™ is available to individuals who are or become customers on and after January 25, 2022."
Introducing Public Points Rewards Announcement:
see the announcement made about the communication error, for your reference, here: https://productioncommunity.publicmobile.ca/t5/Announcements/Public-Points-Joining-Confirmation-Emai...
Other help articles:
https://www.publicmobile.ca/en/on/get-help/articles/Public-Points-Rewards
https://www.publicmobile.ca/en/on/get-help/articles/Public-Points-FAQs
02-09-2023 11:43 AM
02-09-2023 11:42 AM
@bogag517 Some reading to catch you up
https://www.publicmobile.ca/en/on/get-help/articles?q=Points+
