phone number
Jeongbae
this is first time that I got the phone number in canada.
My family has last digit 4834. Is it possible to get the 4834 as my last digit number and cannot find the richmond hill location. D o i need to choose toronto area , so start with 416 instead of 647 ?
@Jeongbae  You can’t customize the number but you can keep refreshing thru the pool of numbers like this
Change # on profile tabs
hairbag1
@Jeongbae
you can look through the list of available numbers in your area and select a new number if you wish to. Chances are perdy slim to find exact number you want...but you can look.
HI @Jeongbae
you cannot really pick a specific number you want.  Of course if you have time you can ask for couple more numbers and keep doing it in the phone number selection
or you can get a temp number first.  After activated, go back to My Account, Profile, click on the pencil besides phone number and then choose number again.   Same thing, it will only give you couple numbers at a time, so you need to keep refreshing it
