12-04-2023 03:24 PM
Hey Folks!!
I have the Canada US plan, and now that I'm in the US I can't make or receive calls. Texts are good, WiFi is great, just no calling... ? Help?
I have turned the phone on and off. No calling still.
Thanks
12-05-2023 02:11 PM
It turned out my Samsung S8 note wasn't compatible. I had to get a new phone... Sad, but now it works.
12-04-2023 04:06 PM
@grizzlybasin If your phone is not VoLTE capable or enabled you will need to try and connect to T-Mobile's 2G network because there is no longer any 3G in the USA. If VoLTE is not your problem, make sure you are set to 4G/LTE and not 5G because AT&T apparently doesn't support PM phones on 5G. Your only options there are AT&T and T-Mobile.
12-04-2023 04:02 PM
PM did let you know that if you're not volte enabled in your phone...talk will not work reliably.
clipped from recent Help Guide..
Note: Please be aware, if your VoLTE is not turned on, you may not have voice or SMS service.
12-04-2023 03:26 PM - edited 12-04-2023 03:33 PM
@grizzlybasin Set phone to LTE and try to connect to T mobile or AT&T , also do you know if your phone / account has voLTE enabled
