04-10-2024
02:07 PM
04-10-2024
03:36 PM
computergeek541
my subscription acivated but my phone number did not transfer...how do i get that to go through?
04-10-2024 03:10 PM
@Willys84 if inbound/outbound calls are working but not imessage and facetime, try to restart your phone. If still not working, contact CS Agent at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 as I've read there's been some issues with SMS messaging with new activations.
04-10-2024 03:07 PM
Transferring from bellMts
04-10-2024 03:06 PM
Gone through the pouring steps and that all went through. I receive and make calls. Just iMessage and FaceTime show on my iPhone as activation unsuccessful
04-10-2024 02:51 PM
@Willys84 What provider are you coming from? I believe Koodo prepaid has a different process where you need to contact PM to initiate.
04-10-2024 02:19 PM
phone number not eligible for port
04-10-2024 02:12 PM
hi @Willys84
Did you get a text from the old carrier, did you reply YES?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
