Account transfer from Roger’s
Mav26
  • I transferred my number 6 days ago - but still can’t call or tex is my old provider likely blocking the transfer?
Mav26
Thanks for your help from the community page.
i am surprised that Nowhere at the time of the transfer info from public explanation tell me to remove the old carrier hard sim once I had activated my transfer to public .
a basic update would remove this service impediment if it clearly stated that.
hi @Mav26
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
slusagm
There is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link:
And CS_Agent will reply to your community inbox, check here:
