06-16-2022 03:24 PM
Last week I had a problem with my Credit Card not being able to be verified by public mobile. this was corrected by an agent. Now nmy phone says its not registered on network. What next ??? . How do I correct this??
06-16-2022 04:26 PM
@iainr wrote:Sorry people, another person on same network was having the same problem looks like the network may have been down. All good now. thanks everyone
HI @iainr There are different posts about network issue today, so, it is possible.
So, your friend is in the same spot as you and have the same problem?
Which city you are at now?
06-16-2022
04:24 PM
06-26-2022
02:54 PM
Luddite
(✅. ..... Luddite)
06-16-2022 03:55 PM
Went into my account and it says I'm registered for dynamic autopay. Everything looks good.
06-16-2022 03:51 PM
@iainr don't just assume it is active. Login My Account and check
For blacklist, check it and confirm.
06-16-2022 03:48 PM
Don't have another phone. Account appears to be and should be active. Have been using this phone for about 2 years now with very light use.
06-16-2022 03:42 PM
HI @iainr
A10e should work on PM
Do you have another phone to test the PM SIM? Just to confirm it is not a device problem
And My Account showing Active?
Also check if your phone is blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
06-16-2022 03:39 PM
samsung galaxy a10e
06-16-2022 03:37 PM
What is the make and model of your phone?
06-16-2022 03:34 PM
tried tha, phone now says network not available
06-16-2022 03:27 PM - edited 06-16-2022 03:28 PM
@iainr Hi remove sim reseat it and reboot phone
