phone locked up
11-22-2021 09:14 AM - edited 01-06-2022 04:03 AM
11-23-2021 08:56 PM
Very unusual. Remember the CCTS can help you if koodo refuses to refund your payment to pm.
11-23-2021 08:49 PM
My problem solved. Koodo found a way to blockphone and take my first month payment to Public. I was able to unblock phone erase Koodo, and made second payment to Public to get phone on. Now I will go after Koodo to get my money back that they stole.
11-23-2021 02:57 PM
11-23-2021 02:53 PM
OP was so eager to solve his problem and opened 3 threads.. but never heard back since.. Let's hope this is a good sign ..
11-23-2021 02:46 PM
@esjliv wrote:
@earlecar wrote:did factory reset, phone locked no internet no out calls
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
@earlecar Where did you purchase your phone? Retailer or private sale?
11-22-2021 07:42 PM
11-22-2021 11:36 AM
Could you reply to your post so we can help you further.
11-22-2021 11:27 AM
What do you mean 'phone is locked'?
What message do you get?
Is your phone unlocked in order to work with Any mobile service provider?
11-22-2021 10:56 AM
11-22-2021 09:50 AM
@earlecar from your 3 topics, we know you have a Moto phone.
But what we don't know is what error message you got? sound like you have a Carrier lock. Was the phone used elsewhere without any problem at all? did you ever use this particular phone in Public?
If it is a carrier lock, you might see an error like this: "SIM network unlock PIN"
If that is the case , you will have to go back to the carrier where you got your phone originally and ask for the unlock code. They supposed to give it to you for free. But if you no longer their customer, they might give you some trouble.
11-22-2021 09:43 AM - edited 11-22-2021 09:44 AM
@earlecar wrote:After two days I factory reset Motorola and need to refresh Public
What do you meant by refresh public? Was the phone ever used in Pubic? Which carrier it was used before
update: sorry, Oracle needs to combine OP 3 threads into one
11-22-2021 09:41 AM
@earlecar what error message was that? can you at least use the phone on Wifi or not at all?
11-22-2021 09:36 AM - edited 11-22-2021 09:38 AM
What brand and model of phone do you have ?
Are you looking for a PUK code ?
Here is an explanation by one if the Oracles, Luddite.
SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
Once the PUK is recovered and validated, you will be asked to choose a new PIN.
Only Public Mobile's CSA can give you this type of code, which the device manufacturer cannot. Public Mobile's CSA can be contacted at the following address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
11-22-2021 09:29 AM
