payment voucher not printed well, can't be read
josh_pmobile
Hi! I bought a payment voucher but it wasn't printed well to be readable. Talked to the store manager but he said he can't do anything, told me to call customer service instead. What shall I do. Thanks
28 REPLIES 28
@softech
Yes @Anonymous is correct only the pin# can be used. I would suggest the user methodically go thru the 0 to 9 possible digits via 611. Using self serve may run into the same one hour time out issue that card attempts also has after two attempts.
 @softech : A certain flowery user made the perfectly reasonable logical assertion that the self-serve used voucher# because it said it there on the screen. But they didn't test it. So I did. It doesn't work.
thanks @Anonymous , you are the voucher expert too
yes, there was a post with voucher bought from SDM and point to a voucher number saying use that for Self-Serve.. i guess that is not correct
thanks for confirming
 @softech : Only PIN# works on either 611 or self-serve. Tested and verified. Voucher# does nothing. I don't know why some of these things have multiple 12 digit sets but it's only PIN#.
barndoor
LOL  ...you would think the voucher number would be the store- PM reference and what should have been used by  the store staff to get the PIN issue sorted .
@darlicious, since you are a voucher expert here..  i have a question.. Can we use Voucher # instead of PIN when entering the voucher on My Account?  I got mixed information from old posts.  One said clearly saying My Account use voucher number but there was another one saying DO NOT USE voucher number
Also, look like not all voucher has voucher number.. or the number of digits are not consistent from the different screenshots
(just wondering if OP can in fact try using the voucher number on My Account as her PIN is missing a digit due to printing issue)
barndoor
I thought he said the manager refused to refund
Maybe as suggested he needs to go over the managers head .
@barndoor   OP issue is unable to get it reprint or refunded from the first store..
honestly, there must be way.. but the store refused to do so.
barndoor
I'd say go to a different store and get a new voucher and go to the old store and get a refund  . Considering the running around you've done  any remaining costs should come from the supplier.
@josh_pmobile wrote:
actually there is only 1 missing number,
Try to enter on My Account.. with just 1 missing number, it's not bad to try 10 times
If tried 10 times to "guess" the missing number on the PIN does not work, try the Voucher number as well.
josh_pmobile
actually there is only 1 missing number, the associate tried to start from 1, then 2 then 3 then we got a message saying " Im sorry we cant process your request blah blah instead of " your pin is invalid", so we waited  few minutes but still cant process. Went home waited for an hour or two, tried to enter pin, still cant process. After 7-8 hrs went back to the store, tried to enter another number but still cant process instead of invalid pin. And i did it with the store manager who happens to not know anything to deal with the problem and told me to contact customer service instead. I nothing will happen, might have to call the store company and ask for a refund
@josh_pmobile
can you visit Here link , to you know what all number.....
@josh_pmobile
you can try to use the voucher number on My Account/Self Serve to load and see if it goes through
Also, since it is one digit not clear, you can try to use the PIN on My Account as well.  It's not too bad to try 10 times I guess 🙂
just PM CS support, waiting for a reply, thanks. I did, asked them to reprint they cant, asked for a refund they dont, so Im here lol.
I would try to take them to Small Claims Court if the amount is substantial.
josh_pmobile
the voucher number is readable, that's the authorization 9 digit number right?
@josh_pmobile  just the 12 digits PIN not visible?  how about the voucher number?
josh_pmobile
Yes If public mobile PM support cant resolve this, I might have to call the store company where I bought and ask for refund
josh_pmobile
josh_pmobile
yes I know how to use it, actually there is only 1 missing number, the associate tried to start from 1, then 2 then 3 then we got a message saying " Im sorry we cant process your request blah blah instead of " your pin is invalid", so we waited  few minutes but still cant process. Went home waited for an hour or two, tried to enter pin, still cant process. After 7-8 hrs went back to the store, tried to enter another number but still cant process instead of invalid pin
LurganIeUk
That is an extremely poor answer from a store manager!!!!!
Can they not do a reprint?
Like will you ever go back to this store?
@josh_pmobile
just to you know where you buy it from, the are responsible issue full refund, or that store has a phone number from that company is deals with it you know, and that store have to make call to them to give you the voucher number to you will Enter in your account, try to go back to that store or get that phone number from store to you make call and give them your receipt number to them give you the 12 digit pin from your payment voucher.
josh_pmobile
circle k at 9910 104 st
@josh_pmobile  curious, where you bought the voucher?
josh_pmobile
@josh_pmobile   you really should have push the store to do something.  There was be a way to re-print
So, there is really no way to you can read the 12 digits PIN   on the receipt?
or the Voucher #?
If not, I suggest you to open a ticket with PM Customer Support and provide them all the information and see what they can do
(After you open a ticket with Customer Support Agent, please monitor your Community inbox, envelope on the top right.  Customer Support Agent will communicate with you via messaging within Community)
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request Cusstomer Support Agent assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot. Start with typing "Submit a ticket", click on "Contact Us", click on "Other" from the choices, click "Click here to submit a ticket" then Follow the prompts to submit a ticket.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@josh_pmobile
visit Here link , to you know how to use it....
 @josh_pmobile : Are there any identifying numbers on it? Do you have multiple 12 digit sets of numbers? If so, use the one that says PIN#.
@josh_pmobile
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck....
