overcharge
dizzyonomike
hi, my june payment was 106 + tax, but my prior payment (march) was 90 + tax. why? after viewing invoices of march and june, there doesn't appear to be any extra charges.
Meow
No more monetary rewards!
No more loyalty nor autopay nor referral monetary credit every 30 days. Now you get 5% off your bill back in points, 10 points at anniversary and 1 point for every referral. If you participate in Community few more points could be awarded.
When you collect 15+ points you have to manually convert them to $15, it will not be automatic applied toward your bill.
@dizzyonomike
as said above , the legacy rewards system has ended and every is moved to Public Points
But what plan you have?? Check the latest plans offered for existing subscribers.  The $34/30 days  might be as good or with more data /service and might be better for you
turtleTurtle
You were probably switched over to the new rewards system. You now get points. You need to manually redeem them for $15 off your bill when you reach 15 points, it is not longer automatic. Check your points history and see if you have received any points. You will get 5% back what you pay in points as well as 1 point for any referrals.
@dizzyonomike
All members on the old Legacy Rewards was mandatory switch to the Points Rewards in May.
Everyone was given notice in March about the switch. You should have gotten 5 points for the switch.
Now you need to collect 15 points to redeem for a $15 credit. You will get 5% in points based on your monthly plan and no more $2 credit for AutoPay.
You will also get 10 points for your annual Loyalty reward.
Phil_Adelphus
@dizzyonomike  Were you on the old rewards system where you got loyalty and autopay discount?  This system was switched to a points system where you pay in full to start with then earn points at 5% of your payments to ultimately use them for a bill credit or discounted add ons.  You may have missed the announcement  in March, did you get any bonus data as compensation for the switch?
