04-12-2022
01:46 PM
04-13-2022
01:14 AM
computergeek541
..Let's see if there is a good answer for this one..
I live in Saskatoon and recently changed my phone number because of someone spamming my number.
I changed it to a Saltcoats, Saskatchewan number, which is 4 hours away from Saskatoon. Because it is very easy to remember.
Recently, a few calls, not all, have been cutting in and out. So is it because my SIM is connecting to a Saltcoats phone number 4 hours away? or could it just be my phone, which has been dropped on the floor a few times too many. Motorola G Power
Thanks for any input!
04-12-2022 03:19 PM
@jtrohak wrote:..Let's see if there is a good answer for this one..
I am sorry to hear. Clarify spamming. Some one is calling you numerous times or some one is spoofing your number?? if you are getting unwanted calls like we all received...build a complete, best ever contact list of friends, lovers, enemies, wife, business, doctors etc...then set a DND setting to only allow calls to you, that are in your contacts list. DND will still let the call to go to VM and set up your VM to ask for name and phone number and a message...from there add to your contacts or block the caller. It works!!!
Thats nice...but do your local friends and businesses etc now have to call you LD as not everyone has Canada Wide Calling.
NO, your are connecting to the nearest Telus or shared cell tower in Saskatoon....same as before.
Perhaps...or a faulty SIM....can you try SIM in another phone?
04-12-2022 01:59 PM
Most likely the latter as it could have rattled the sim card holder internally among other things
04-12-2022 01:59 PM
@jtrohak I see you have a Moto G Power phone, if it is a Canadian or US version of the phone, it should work without issue. But it could still be a device issue. Try to get a good working phone from friend to test, put your PM SIM there and see if it works better
04-12-2022 01:54 PM
I really doubt phone number has to do anything with your location. I expect my phone to work IN BC even though my number is in ON.
BUT, knowing you had mishap (few times) with your phone maybe some contacts with SIM card become loose and are loosing connection.
04-12-2022 01:54 PM
@jtrohak , the location of number does not matter. It is a connection issue
What kind of phone do you have?
Try to reseat your sim once (power off, take out the SIM for a minute before putting it back in and power up)
If still not working well, try to change the Preferred network type to 3G ONLY/WCDMA ONLY and see if it helps
You can also try to reset Network and see how it goes
