02-25-2024 01:06 PM
when I go in to the PM app it keeps trying to install an eSim on my iphone.
I don't want an eSim installed.
I have a physical sim card from PM that I want to use.
How should I proceed ?
02-25-2024 01:19 PM
From your previous post, you had a porting issue yesterday.
Likely your account was not set up properly before you fixed your porting issue.
You will need to contact customer service agent.
Send a private message to CSA through the following link :
No phone number to call. Just the private messaging system. It usually will take a few hours for CSA to respond.
02-25-2024 01:18 PM
@dxfinlayson Could you have accidentally selected esim when you were activating? Either way you can contact customer service using this link
An agent will reply at the envelope icon top right or tap your avatar for Messages.
02-25-2024 01:17 PM - edited 02-25-2024 01:18 PM
Hey @dxfinlayson
During the sign up, it will give you a chance to take a picture of the bar code on the SIM card. Try that. That is how I signed up my neighbor.
How to sign up with Public Mobile
