Won't connect
02-25-2024 12:52 PM
Just installed a new SIM and phone won't connect to network and there's no support.
Any chance getting help?
Service
02-25-2024 01:16 PM
02-25-2024 01:15 PM
That is odd. It seems you were able to pick a phone number cause it wants to send it to you. And for some reason it doesn't want to send to your email. Crazy system.
Maybe it's time to reach out to a CS Agent to fix that for you. Here's the link.
Just know that due to these new promo's that came out, there is about a 12 hour wait time. Don't let that detour you. These prices are awesome. And once you're in, you'll love it.
02-25-2024 01:13 PM
Im an idiot, I needed to restart the phone 🙈 thanks everyone. Have a great day.
02-25-2024 01:13 PM
02-25-2024 01:11 PM
02-25-2024 01:09 PM
I did that about 50 times now haha
02-25-2024 01:08 PM
new number.
02-25-2024 01:08 PM
02-25-2024 01:07 PM
keep clicking on Resend Code
02-25-2024 01:04 PM
this is where im stuck. Phone wont connect to network.
02-25-2024 01:02 PM
yes! i did the activation via the app (using wifi).
Now its asking me to verify the account via text message.
But i cant connect to network to receive the txt.
02-25-2024 01:02 PM
HI @MajPayne
is the QR code ask you to download the PM app? if it is , downlload it via Wifi and finish the activation, you are not done yet if you have not got to phone number choosing or porting phone number
02-25-2024 01:00 PM
02-25-2024 12:59 PM - edited 02-25-2024 12:59 PM
Oh. Ya. That happens often. Here, try this.
Can’t get the 6 digit 2FA code to your phone?
First, sign into your account at www.publicmobile.ca and use the email you signed up with and the password. If it asks you for a 6 digit code, it will say at the top left CONFIRM YOUR IDENTITY.- Enter the 6- digit code sent to *********. But it’s not working!!! As you see by the screenshot below, 1. Click the This is a trusted device. 2. Didn’t get the code? Click on that.
Then, the next window that pops up is this.
Click on Send email. Here it will send you the 6 digit code to the email you registered with. This step is very important. Do not just copy and paste. Enter each digit using your keypad.
You should now be able to get into your account.
Created by Chalupa Batman
02-25-2024 12:58 PM
More details would be helpful. Community members on the forum are customers like yourself. Offering troubleshooting advice. Unable to access account information.
New customer? Did you port over your number? If new activation, did you finish your activation via the PM app. Physical SIM versus eSIM? The more details the better.
Sometimes a simple reboot of phone solves the problem.
02-25-2024 12:58 PM
I just bought a new phone and got a new sim card at the store.
I bought the plan and now they asking to confirm a code via text message but my phone wont connect to the public mobile network.
02-25-2024 12:56 PM
First and foremost, did you log into your account to change your account to the new SIM card number?
02-25-2024 12:54 PM
hi @MajPayne
physical sim card?
do you have another phone to test? Try click Reset All networks
if esim, make sure you removed all other physical sim card
if still not able to connect, probably just setup problem, CS agent can help. please submit a ticket with CS Agent here:
