3 weeks ago
I just bought minutes to call from Canada to Colombia. When I dial the number it says 11b1 your call cannot be completed. What do I do?
3 weeks ago
Thank you, now it works!
3 weeks ago
try dial +57, area code, number. Aletrnative dial 011-57-area code-number.
3 weeks ago - last edited 3 weeks ago
You bought the correct 300 Minutes Long Distance add-on?
how you make the call? what dial sequence you used? it should be 011 57 [area code] [local phone number]
try reboot the phone and try calling again
