notifications
02-01-2025 09:04 PM
02-01-2025 09:28 PM
hi @sneezycat1
then you will have to ask support to add it back
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
02-01-2025 09:26 PM
@sneezycat1 wrote:I mistakenly opted out by hitting stop and now I want to receive them
You will have to create a ticket and ask to have you put back on the list.
You can submit ticket by direct message:
02-01-2025 09:24 PM
02-01-2025 09:19 PM
HI @sneezycat1
yes, you can
if you meant those system text, either reply STOP or you block *611
if you meant Community notification , just go to https://productioncommunity.publicmobile.ca/t5/user/myprofilepage/tab/user-subscriptions:notificatio... and check mark Turn off all email notifications
02-01-2025 09:18 PM
@sneezycat1 The texts will come from PM (either from 611 or a 4 digit short code ex: 5072)
You can remain to stay subscribed or opt out of future texts at that time. Hope this helps
02-01-2025 09:15 PM
@sneezycat1 wrote:How do I turn on receiving texts from public mobile
You don't really. They come automatically. There is an option not to receive them but I think you have to enter that in once you get one. Most text messages that come from Public Mobile are mostly targeted offers though.
