need to redo my credit card inofrmation
JeffTorrans
Hey Public Mobile, really starting to hate your utter lack of service.
I got a new CC and need to update the info.  No way to log in and no codes ever sent for a password reset.
Totally stuck without a phone.
Meow
While My Account is not accessible not much you can do. You can try contacting agent to update your CC.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
dust2dust
If you're suspended then do you know your 4 digit account pin? Or buy a voucher online or in stores then dial 611 to enter it and then your will reactivate.
That way you'll have service back. Then whenever they fix their stupid system you can update your credit card.
dabr
@JeffTorrans   Unfortunately, PM is experiencing ongoing issues to the self serve system, so you can send a private message to CS_Agent and ask them to assist here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Other option is to purchase a voucher from SDM, London Drugs, 7/11 or Shell and add the funds by dialing 611 on your phone.
