11-18-2022 01:54 PM
It been 62 hours since my new 4G plan commenced and i still do not have 4G data speeds.
Speed is still the same as previous 3G plan?
11-18-2022 02:22 PM
drops tp 4.3 mbps then 2.1 then 7.2 mbps
11-18-2022 02:20 PM
6 to 8 mbps. Is this 4G speed?
11-18-2022 02:06 PM
@Walt38 make sure on your device, the preferred network type is set to something eith LTE or 4G there
and reboot your phone once
try data speed test in different area and not just your home
(BTW, what speed you are getting??)
11-18-2022 02:06 PM
@Walt38 wrote:Yes the new 4G plan was activated Nov.16.22 but 4G data not working
What kind of test speed are you getting? Speed tests can produce non repeatable and very different results each time.
11-18-2022 02:04 PM
11-18-2022 01:57 PM
@Walt38 , please access your self serve account using incognito mode on the browser to make sure that your plan change to a 4G speed plan has completed successfully. On your phone, check that you have 4G network as the preferred option.
11-18-2022 01:56 PM
Have you switched your cellular setting to LTE?
