01-09-2024 06:21 PM
to request a sim card and enter my account I need my phone to receive the security code, only problem I lost my phone, so can't get to my account to request a new sim card or transfer the number because I don't have a phone this is kind of a catch 22 situation !
01-10-2024 09:53 PM
@balialf19639000 wrote:I don't get the option "Send again as Email" only "Receive a Phone Call" or "Text Message" to both I need a phone which is Lost!
You don't get that option the first time a 2FA is sent (by SMS).
But it you click "Didn't get the code" then you'll be prompted to send again as SMS, send again as email, or send again as voice message.
Yes, you can't receive the SMS if you don't have your phone.
But you can login to your email from any device on the internet. And you can check your voicemail from any other phone (by dialing your own phone number and entering your voicemail PIN).
01-10-2024 03:33 PM - edited 01-10-2024 03:34 PM
@balialf19639000 Yes they will be able to help . Usually they reply with in the hour sometimes longer but
01-10-2024 03:31 PM
don't know why but this time your link worked! I've contacted the support person hopefully he can help.
01-10-2024 03:29 PM
@balialf19639000 Did you try the private message link while you were logged in to this community? You don't have to be logged in to your phone account, just this community.
01-10-2024 03:09 PM
@balialf19639000 When you click the link you should see
just type your message and hit send message it’s auto filled to go to CS agents
01-10-2024 03:03 PM
hi, thanks for your reply but,
Your link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
opens a page to private messages but it does not allow me to write or do anything at all, please don't tell me to log in to my account because I can't I lost my phone and it wants me to verify my account via sms or voice call I don't have the phone I have a new sim but I need to activate by login to my account
01-10-2024 11:40 AM
@balialf19639000 Please use the direct link to support in my first reply bottom of page here
01-10-2024 11:21 AM
01-10-2024 11:20 AM
01-09-2024 06:40 PM - edited 01-09-2024 06:51 PM
Try to login, EverSafe will send an SMS.
Then click "Didn't get the 2FA" ... then you'll get two options "Send again as SMS" and "Send again as Email"
While you're in Self-Serve, you can activate a new SIM card (if you already have the SIM card and can read the number off it) - you can't activate a new eSIM since to do so you need access to the app on the phone you don't have access to. Or you can report your phone as lost/stolen to temporarily suspend all service to it.
If you've ever logged onto your Self-Serve or your email from your missing phone then I recommend you change these passwords to secure your phone. Indeed, it's smart to change all your passwords to everything anyways, just in case, especially for your Self-Serve and your email(s) and your bank(s) and credit card(s) and payment site(s) and maybe even your social media site(s) - just so that a new "owner" of your phone cannot screw you over, steal your identity, drain your funds, etc.
Ignore the copypasta advice others are offering about this. If your phone is currently in the hands of a malicious or criminal person then every second could make the difference. Damage control immediately. Don't wait for a distant customer support agent/team to eventually get around to starting an impersonal support session and asking you questions ... by then it might be too late.
01-09-2024 06:36 PM
@balialf19639000- if you say you didn't receive the code, it should give you an option to receive the code by email instead.
01-09-2024 06:32 PM
@balialf19639000 You should be able to order a sim card without being logged in to your account here
https://store.publicmobile.ca/cart
Having said that, it would be quicker to get one from a corporate Telus/Koodo store that has them in stock, or order from Amazon.
Have you tried to get the security code by email?
01-09-2024 06:25 PM
@balialf19639000 Get support to help in this case
send a private message To CS_Agents
